I'm going out on a limb here as a new forum member.
I own 4 passive Penta's now. When I bought my first pair (second-hand) I was impreesed by the sound they produce. They've got a big soundstage and sound huge. But after longer listening I found them to be lacking in transparancy and timbre. After finding the specs of these speakers, iI found out that they only reach 20KHz at a -8 dB point. I took them to a speakershop and had them measured, and indeed the high's are tempered, and the bass is a bit boosted (40HZ measured in at +2 dB). That explains their huge sound. But i wanted them to be more precise, more neutral. To achieve this I examined the filter used in the Penta's, and after some calculations and experiments have found a very easy (and reversable!) way to make the Penta's sound more brilliant, sparkling, more balanced in frequency so to speak.
Inside the Penta's at the bottom, there are two PCB's containing the filter. One PCB is labeled No. 14 and the other No. 15. If you short circuit R3 on the PCB No.14 the tweeter in the Penta is no longer held back and the overall sound of the Penta's clears up! They sound much more neutral and livelier.
It's an easy and cheap way to influence the sound of the Penta and best of al. if you don't like the sound, remove the short-circuit and all is as it was.
Just wanted to share this with you
