Hi I want to replace hubby's headphones. They are Form 1 and about 15 years old. He uses them with the Ouverture and 9000. Can any one recommend a new one or should I leave alone. H
Updating headphones
Have you considered the Form 2? They don't sound as good apparently, but still lovely headphones
Depending on how much you are looking to spend you may find the Sennheiser HD600 or HD650 to be a better option than B&O headphones, as they are arguably the best headphones on the market. Sennheiser also have numerous other alternatives lower down the range starting with the HD201 for about £15 (UK) and working up from there.
Simon
HD600's or 650's are significantly better than the Form 1's but are quite expensive (I have seen then as low as £139 in the past but a quick search at the moment shows them to be considerably more).
I don't think Form 2's are a serious option for "real" listening, I agree with Simon - look at Sennheiser or Grado.
A mid-price alternative would be these:
Form 2 sound better IMO, better bass. Form 1's are more comfortable to wear though.
Craig🙂
I am very happy with my grado sr80 headphones and they are very well priced.
Hope that helps
Cheers Nick
Thanks for the Sennheiser link. Still undecided will look at some Grado(never heard of these). H
Push the boat out and get the HD600's - he'll love you forever😕
The Grado's are good but (arguably no better and) he'll spend the rest of his life looking like "Phones" from Stingray!😁
If you want to make the ultimate style statement it can only be these
