Update NL/ML converter
There is a new software update also on the NL/ML converter. Added TV ON, Music ON in the IR mapping. Have to find out the advantages...
Current Version : 1.3.0.0
Release Notes:
  • Removed H8 telegram logging to /tmp.
  • Removed thrift client connection and disconnection notifications.
Edit : Spotify did not allow this, but Deezer can be used in your link arrangement.
Thanks for the Information.
How can I update the converter? When I try to access the configuration Panel via my Internet browser I am asked for username and password...
Try : admin
If it does not work you have to reset the converter
Maybe it already is updated - if set to 'automatic update'.
Thanks, it has updated automatically.
admin / admin works as login by the way
