Update APP of the B&O 7.0.0.
Hello MM, weird, mine is an M4 mac mini. Regards, Johan
No problems on my Mini M4 either - same version.
Very strange. Work fine for some but not for others, all with M-processors. Especially strange that it works on one Mac Mini A4 and not on another…
I have tried to delete and download the latest version of the B&O app, plus running MacOS on latest version. Though, it has never worked for me (have tried for a year).
It works fine for me on my M1 Max Studio and my M4 Mini. Maybe look to see if it hid some preference on your Mac which can linger even if you delete the app itself.
All versions including the new 7.4.0 beta work on my Mac mini M4 And Mac Studio M1 Max.
Really strange. No version of the B&O app has worked on my MacBook in the last 15 months…
I will have to dig around and try different settings, but I have to my knowledge never changed any of the standard settings. I have installed some windows management apps as I have a 40” monitor, but the B&O app doesn’t work either if plugged into the external monitor or in laptop mode.
What exactly does it do? No instal or get stuck at a launch screen?
Good evening))
Would you be so kind as to check the latest version of the 7.4.1 app?
In the + add device section, I don't have the Beovision Contour icon, but I only have the Stage icon labeled as Beovision Contour. That is, when I select + add Beovision Contour, I only see the Stage icon labeled as Beovision Contour.
If you also experience this, please inform B&O so they can fix the issue and restore the Beovision Contour icon.
Hello (sorry not answering Vedet's post), but I can report that the app 7.4.1 works for a large extent on my (M4) Mac mini now!
Still on the iPhone I have some troublesome playing DLNA albums (shuffle not working as it should).
Regards,
Johan
