Update APP of the B&O 7.0.0.
Hi, I am in contact with the support team too. I reported that the button to add an album is there, but that I have not been able to make it work.
Furthermore that returning to the player, a lot of '<' clicks are needed.
Keep you posted.
J.
Hi all,
I had a friendly conversation with the people from support pointing out the issues and was asked to wait for updates. And... the App is on 7.1 since yesterday (BeoGrace added), and it is now possible to add a full DLNA album to the playlist! I call it progress :-). However, when in the DLNA music collection, you still need to click all the way back to the home screen to control the playlist. I trust that will be fixed?
Regards, Johan
Thanks for the update. I, too, informed B&O Support about the DLNA problem, as I noted earlier. I then deleted the app and decided to wait for a newer version. When I actually think about it, I'm not sure why I even bother with the app as I can play music seamlessly by streaming Deezer or Apple Music (i.e., the same as in the DLNA library) directly to the Beosound Core.
Regardless, I downloaded App v.7.1.0 and it is as you say. DLNA albums now play as they should. Sort of... The DLNA function in the app has been somewhat clunky for a while.
Hi, I think the app is getting better and better, still it is not perfect:
Today I informed the customer service that the player is having some difficulty with the 'random/shuffle' functionality. This is sometimes switched on by default, and sometimes appears to be off, but still plays in random mode with no way to to switch that off.
I like to play music through the app (because of my crave for a full B&O experience :-)) so will keep on informing them about what I experience.
Regards, Johan
the app is now at 7.3.251212552, both iOS and MacOS.
I did not know there is a MacOS app. Where do you find it? I cannot find it in the regular AppStore.  Is it somewhere on the B&O-site? I have an MacBook Pro M1 Max and I have tried to use the iOS-app but it does not work for me as it freezes on a background pic. AMacOS app would be great.
There is no Mac app. Anyone with a M1 or higher Mac can install the iPad version on their Mac.
The strange thing is that on my Mac (16 inch MacBook Pro M1 Max) the iPad app only shows an animation (see attached screenshot) on most of the window, and then there is a white field on the right side of the window. No menus/buttons available. I have tried to reinstall the app, but without any success. Same animation shows.
Han anyone else had the same problem with running the iPad app on a Mac, and managed to get the app to work?
Attachments (1)
Hi Bill, same here, no go. I did once ask B&O, they said: 'As for the MAC mini, please be informed that the app is supported on phones/tablets but not on the desktop. '.
Regards, Johan
No problems on my M2 Macbook Air. It is the latest version (from 23. Dec 25).
