Update APP of the B&O 7.0.0.
Good afternoon!
The application has been updated to version 7.0.0. and I will not find a very convenient function that was implemented in previous versions through the "Support" section - this is a wheel that shows the quality level of the connection over a Wi-Fi network and the SSID of the connection network.
With this function, it was possible to adjust the position and location of the Wi-Fi repeaters in order to achieve a better connection and its stability. It may have been moved to another section, as I was always puzzled by its location in the "Support" section when it should have been in the "Settings" section. However, I could not find this feature in the 7.0.0 update.
If anyone knows its location, please let me know.
Additionally, I noticed that the Beovision Contour image has disappeared, and I am unable to select either the view or the color. Instead, I am presented with an image similar to the Stage image. This is quite strange, as the Beovision 11 and 14 images remain in their respective locations. I wonder what the problem is.
V7.0.0 also removed:
1. Ability to play an entire folder of songs via UPnP DNLA.
2. Ability to close the Music Browser from any view. Now one must back out all the way to the root view to close the music library browser.
3. Adding a song to the Play Que no longer closes the Add Song dialog -nor is there any audio or visual confirmation that the selection was added to the Play Que.
It also was necessary to re-add my Home Media server to all IOS devices after the v7.0.0 “update”.
The app still appears to have no means of clearing the Play Que other than one song at a time.
Not sure why there is so little effort made regarding DNLA integration. Happy to hear of any solutions found for any of the above
Joe M in WV
Joe M in WV
In the updated 7.0.0 app, the Bevision Contour image has been replaced with Stage for everyone?
Just FYI 7.01 is already being tested and fixes a lot of other problems. Hopefully it addresses these issues as well.
My Tablet, Android 13, has been updated to 7.0.0 whilst my phone which is Android 14 is stated to be no longer compatible.
Strange.
Paul
Strange.
Paul
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
Jmen wrote: It also was necessary to re-add my Home Media server to all IOS devices after the v7.0.0 “update”. Not sure why there is so little effort made regarding DNLA integration. Happy to hear of any solutions found for any of the above Ah, interesting I've been fighting with the B&O App for a few days now trying to get it to pick up my MinimServer which worked in the past when I was using Android phone but switched to the Apple echo system, but never came around to config the home server options until now. So are B&O ditching DLNA support in general or is it just early version bugs that we're seeing with v7.0.0 of the app?the trick to get Minimserver back on track is:
- delete the server (if present)
- restart the B&o app
- Now Tidal is shown instead; choose the settings icon
- choose HomeMedia
- Add new
- then restart Minimserver (on another device) and Minimserver will show up
- select the + to add Minimserver
So, no possibility to start a whole album.....
No, way to add something to a que.......
v 7.0.0
Also, the update does not work on my Mac, you only get some nice B&O imagery:
J.
