Glad I can help you.
Make sure you get a adaptor for input (like this one: http://www.svideo.com/scart.html).
Some do have a switch to control input/output.
Also make sure the connector has a stereo sound input, as the digital coax inputs on the Avant are for VTape and AV ports only.
Then you can upgrade your Avant in order to control the ATV directly from Beo4! Ask your dealer.
Good luck
Cool, I'll go for such an adapter.
Additional questions:
- Is there a special reason to use the decoder scart input and not one of the others?
- I would buy an adapter that offers also a S-Video (S-VHS) input. Do you know whether this will work with the Avant scart input? I read the scart input has to be S-VHS "enabled".
- Concerning Beo4 control: Is this upgrade a software upgrade? I read something here in this forum about a version 4.7j but thought that was only for the US version of the Avant. I've no STB controller. Is this a requirement?
Thanks again for you help!
