Unpairing BeoSound 3000 from tv
Hello people,
I was messing around plugging my BeoSound 3000 into the powerlink connection port of a BeoVision 7-32 and now it won't respond to its remote or the volume keys (says 'use tv') - can anybody advise me on how to reset the BeoSound/Beo4 remote to the default setting? I've played around the A-OPT and V-OPT settings on the remote but no joy.
Thanks, Jonathan
Assuming your speakers are connected to the BS3000, both TV and BS should be set to A Opt 1.
Pull the mains from both units. Connect the Masterlink cable. Power up. Set the Option.
Hope that works.
Sorry, but you'll have to set the TV to V.OPT 1 and BS 3000 to A.OPT 1
Thanks Vienna. My bad 😳
Thanks everybody for your responses - in case it wasn't clear from my post, the BeoSound 3000 is in a different room - I want to use it stand alone, not linked to the TV in any way.
