I have just discovered this new
UnityRemote, universal remote for iPhone, compatible with Bang and Olufsen
Hi Phil,
thank you for the info!
I have downloaded the free app on my IPod touch, but it crashes in the demo mode every few minutes. I think it´s because of IOS 4.2.1 on my IPod, which is not officially supported yet.
I also don´t believe it will work fine with the whole B&O equipment, so I will not purchase the device.
Although it will only work as one way remote, the idea is brilliant, espacially the customers can program the app by themselves. B&O should also offer such a device for use with the Beolink app (without Masterlink Gateway), but I don´t think they will do so. If B&O would bring out such a device for their Beolink app with bluetooth for one-way remote or with WiFi for two-way remote, nobody would need a Beo 6 anymore!
I wish you a happy christmas!
Räuber
Thanks Phil, great idea and the first of many such apps in the future I think.
Agree with Rauber that B&O should embrace this concept and launch one themselves that doesn't need the MLG to function.
I can not find any confirmation, that the Gear4 unity remote is working with Bang&Olufson equipment. Do you have any confirmation?
O have ordered it and its works with my Ouverture. Ilittle difficult to install.
Hi there,
is there any new information 'bout interacting with B&O?
B&O should now open up! Every new TV, DVD or Bluray device can be fully controlled with the iPhone.
Best regards
Joe
Hi Guys,
I dont know if anyone have noticed, but Bang & Olufsen them selves have an app for iPhone and Android Phones.
Yes, that's true.
The application is now about 1 year or even more in the App-Store, but unfortunatelly you have to own a Master Link Gateway, which costs about 2000,- Euros!!
And there is much trouble with the iPhone handling and controlling.
B&O has released a "Workaround solution" for this problem:
"Bang&Olufsen recommend to use the Beo4, Beo5 or Beo6" ... thats the answer when you ask B&O for help, AFTER you spend that much money in a solution! Crazy, isnt it?
Best regards
joe
Hi Guys,
Great, but as has been pointed out, the MLG is still required. One step forward, two steps back!
