Unicable & Beovision
Dear beoworlders!
thinking about a satellite dish I was Told to Set up the cabeling as "Unicable"; meaning that 8 Receivers can Show any program with the Signal from One cable; are beovision internal Receivers are able to Talk this Language? And if yes from which Year on?
best Regards
Elmar
so nobody any idea?!? - read in the german forum that it would go (BV 11 already able to be connected to unicable [Satellite channel router (SCR) oder link Channel Stacking System (CSS)]
but I've noticed that BV11 and new Avant both have two connectors for satellite signals - for me it appears that I would need TWO satellite signals to run the twin receiver...any ideas from you, experts?!?
best regards
elmar
hello again!
Anyone watching TV on the new Avant with satellite signal over unicable/CSS/SCR?
Elmar
I think Unicable is unlikely to be supported by B&O.  It was in the original UK Humax receivers behind a hidden menu and I successfully use it but Humax have removed it completely from their new line of UK Freesat receivers.  I also note that there are no third party receivers on the Unicable
