I have a beovision 3-28 from 2003. What freeview box should I go for as the UK
Changes to digital tv in April 2012?
It all depends on what you want to spend and what you want the freeview box (STB) to do. Do you want to just "convert" the TV to link or take advantage of link and be able to record and or view another channel at the same time.
I live in Devon and our analogue signal was one of the first to be turned off!! I Have a non HD BV5 and use a Humax PVR 9200T with a twin tuner and 320GB hard drive. This model was in the STB controller list on the TV so works with my Beo4 & Beo5. It allows me to watch one program and record another or record two and watch a third depending on wich channel they are.
I chose Humax as they have an excellent record for updating the software even on the older models, they seem reliable and are very easy to instal and use. I bought mine
I will second the Humax bx's in fact mine is also a 9200t :)
I have just switched from a Humax Freeview 9200T to a Humax Freesat HDR box (for out here in Denmark) - both are great. And if you buy direct from Humax they do some Manager Specials: 'Grade A' refurbished boxes with full warranty...
Not sure about Freeview HD boxes and the BV3 as I don't think you get any gain on a CRT TV.
But Humax seems to be very popular :o)
Stoobie
Many thanks. Not sure which route I will go but this will definitely help me.
Hi. Haven't been on this site for ages but just happened to be browsing tonight and came across your enquiry. You don't say if you have the set top box controller for your BV3 but I have in my BV3 32 and use a Nokia 221T which works nicely with my Beo4. However, I would advise that this box itself can be troublesome and I regularly( once or twice a week) have to unplug it from the mains and plug in again to unfreeze it. Updates have to be done in stages - Google Nokia221T problems- and you will see what I mean.
I have also used before the Panasonic TUCT20, again ok with Beo4, but this completely packed up on me. If you don't have the set top box controller then I guess any Modern freeview box will be ok as you wont need to use your Beo4 with it anyway. I also have a Panasonic DVD recorder with inbuilt freeview.( No Beo4 control either). Recording may be another consideration for you.
Graeme.
