One thing that should be considered is to avoid using SD cards when running with application which might be quite intense on using storage. You might very well have a corrupt SD-card in 6-12 month and there I would recommend making use of disk instead. Take an old SSD disk and attache it using a USB-SATA dongle and you'll avoid such issues including lower power consumption than a standard HDD.
Twonky on Raspberri PI for the Moment - a simple guide
Thank you for this guide.
I have followed it with the latest version of Twonky and cannot get it to start. After running the twonkystarter I get
bash: usr/local/twonky/twonkystarter: cannot execute binary file: Exec format errro
any help greatfully received.
thanks
Hmm, are you running the correct Twonky for your Operating System ?
I have sold my Moment, so I have not tried this in a very long time. Can you try and download an earlier version and see if that works ?
/Jacob
Thank you, i replaced the version with the 8.4.1 instead on 8.5.1 and all works.
what are you using instead of twonky i you don’t mind me asking?
Diccon
Diccon
Nothing instead of Twonky :) I sold my Moment...
/Jacob
