Hi All
This is quite a long thread, but I decided to try and get Twonky running on a Raspberry PI 3. The only thing it will be doing is serving the Moment with my CD's ripped via iTunes in Apple Lossless format.
Here is what I did.
1. Bought the Pi including a case and a 32GB micro SD card, and put it together.
2. Downloaded the Raspbian image with GUI from
https://www.raspberrypi.org/downloads/raspbian/
and followed the installation guide regarding writing the image here
https://www.raspberrypi.org/documentation/installation/installing-images/README.md
3. After that it was only a matter of connecting the PI to mouse/keyboard/monitor and inserting the SD Card, and power it up.
4. After it has started, I configured it to connect to my Wi-Fi, and enabled SSH to be able to transfer my music via SFTP later.
If you do not change the standard password for the PI user, then you will get a warning on every startup
5. Now it is time to install Twonky, so create a folder for Twonky and set the permissions so you can extract files to it later.
6. Download Twonky for Raspbian and extract the files to the newly created folder.
7. Twonky need to have the correct access to the files, so change that.
8. Try to start Twonky and see if it actually works. Check it by opening a browser on the PI and go to http://127.0.0.1/9000/webconfig
9. If all is well, configure Twonky to start automatically when PI starts up. Edit the file /etc/rc.local with the nano editor
To exit the editor and save the file press ctrl x, y, enter.
10. Reboot the PI and go to your Moment and verify that the DLNA server shows up on the Moment. After a while it will fish processing and find no content.
11. Configure Twonky to look for music in the pi users home library.
12. Connect to the PI via SFTP and transfer your music the the folder configured on Twonky.
13. Verify that the music is available on the Twonky server.
14. Give the Moment some time and see that your album now is ready to play :)
Now it is just a matter of copying the rest of the music the the PI and sit back and enjoy DLNA music from a small and energy efficient computer :)
/Jacob
