Tvix 6600 and Beo4
I have a Tvix 6600 which I operate with a Beo4 via the puc-list ( Tvix 6500).
My problem is: I can't change the audio with my Beo 4 (by pressing "menu" and then the yellow button), but with the original Tvix remote I can (but this can only be done directly on the Tvix, which is in another room...)
Does anyone recognize this / have a solution?
Hello Doc
The remote control of the Tvix 6600 is one button diferent from the 6500 one. Audio on the 6500 is MUSIC on the 6600, and the Audio on the 6600 is a new button. The new PUC for the Tvix 6600 is already in the Service Tool, so you need an update of your Beovision PUC list.
Regards
Hello Quim,
Thanks for your answer.
Doc
