TV: what's the difference?
What's the main difference between beovision 6 and beocenter 6 apart from the screen size of the smallest model?
Beocenter6 can be equiped with a radio (hence the beocenter name), and has a metal speaker grille.
Not much difference then...
Thank you for the information   🙂
Also a newer, better, brighter LCD display
Would you then recommend a second hand beovision 6 (22") on motorized base at around £1700
