TV Recommendation
Thanks for all the suggestions.
A BV-11 + converter or a Beosystem 3 TV seem to be good options.
Does anyone know if the digital tuner system on Beosystem 3 supports UK HD? The one on the Beovision 8-40 doesn't anymore...
Another query - I get the idea of adding a newer smart tv - but can these be run if 'monitor' mode?
And, I guess, if they can is there any advantage anyway?
Alan
Sorry a (hopefully) final question.
If you're using a Smart TV with a Beosystem 3 and using the TV itself as the primary 'collector' of signal inputs (eg TV antenna, iPlayer, etc) - how do you transmit audio from the tv to the beosystem 3 for onward distribution to attached speakers?
Normally I would imagine new TVs do this via bluetooth (eg to a soundbar) or via optical output - I can't see either of these are input options on the Beosystem 3.
You can use the (e)ARC HDMI from the tv to a free HDMI input on the BSys3…..that will have to be configured and activated with the B&O remote, when you want to listen with the speakers connected there.
Also the volume is controlled with the B&O remote.
Personally I find this a bit fiddly, but it is doable.
With my LG OLED TV connected I use the headphone out of the TV to red/white RCA plugs into a SCART convertor on the BS3. This works perfectly for me and the volume is controlled by BEO4/BS3. There are S/PDIF sockets on the BS3 but I don't know enough to use them. You will not be able to distribute any sound that comes in via a HDMI cable without a digital to analog convertor as ML cannot distribute digital sound. This may be the same if you use the S/PDIF.
I do not use the tuner on my BS3. It can get UK Freeview HD but I rely on the TV for that. I also use a BEO5 remote so I don’t need the TV remote. It doesn’t do th Magic remote stuff but is perfectly useable.
Basically I got the BS3 for the same reason you are considering because I have ML everywhere and moved from a BeoVision 5. At the time a newer B&O TV (plus nearly £1k for the NL/ML converter) were well out of my price range.
Exeter,
Devon,
UK
Hello pestria, all,
I do use a BeoSystem 3 with an LG Oled. The LG is used as the 'video hub' (AppleTV 4K connected), and the BS3 as the 'audio hub' (MasterLink connected to BM6500/CD7000, BS5, Core) with BL2/7/6000/8000.
I feed the LG's optical audio output, via an optical/digital converter, into an S/P DIF port of the BS3. It carries Dolby Digital.
The audio signal of the TV does get distributed over ML, it must be that the BS3 does some digital/analog converting for that.
Maybe this helps in your decision-making. Regards, Johan
Hi
Thanks everyone for the great advice.
Most appreciated.
Alan
Just a word of warning! My BV11 has just failed. B&O official repairer has diagnosed (by telephone and following his instructions) that the panel has failed. They were specifically made for B&O and replacements are no longer available.
BV11 was a fantastic tv but apparently now (in my case) beyond repair.
I love the look of the BV-11, however I'm drawn to the Beosystem 3 solution overall.
Panels go kaput and are being updated all the time - this leaves expensive B&O options vulnerable.
Using the Beosystem 3 will hopefully give a more than acceptable sound which can be linked to whatever quality panel is desired - so for us who have ML it seems a very sensible solution.
I started this thread a few months ago - and never made a final decision.
Basically this is down to the fact that I'm no longer sure a B&O TV is that much of a good idea.  Even B&O themselves are going down the road of considering the panels an updatable item.
In a nutshell we want a good quality panel connected to B&O sound.
'B&O Sound' would mean a soundbar for normal tv but be able to utilise our Beolab 8000 for music stereo.  If we could 'pull' ML into the sound system then that would complete the perfect set up.
I've looked a Stage - but can't see how you'd connect the Beolab 8000s or ML.
Beoconnect Core - does the stereo music ok, but not sure how you'd connect a soundbar (Stage) for normal TV.
A Beosystem 3 - this does ML and music stereo.  Could it send output to a Stage?
Any help once again would be gratefully received.
What other pieces do you need to use on masterlink ?
If it is speakers in a seperate room , with a processor like the Emotiva I had you can add them as a zone , or you can add an Apple AirPort Express and get them on the WiFi network , then stream to them . A lesser quality option is to add a Bluetooth adapter to link a phone etc .
The Apple way will a;so work in reverse if needed , eg: play cd on the network .
Also b&0 speakers can be used with any brand of equipment , though the easiest way is to buy something with rca outputs for surround etc and a 12vdc trigger output on mini-jack .
I will add a picture of a system I ran for a while using a Vizio 4k smart panel , outlaw/Emotiva processors and meridian/Oppo disks.
Apple TV , dvd etc hdmi to processor , and arc-hdmi from smart apps in tv to processor .
I still have the adapter cables and the little outlaw surround processor if you are interested in buying them ?
Also the 7-1 and 65” tv , but that might prove a little bulky to ship !!
I have a b&o pc box somewhere that I never used , maybe research if one of those can integrate masterlink into whatever you end up buying .
