We're looking to upgrade our BV8-40 main room TV.
We're committed to a B&O model, so we can continue to enjoy ML compatibility with our music sources and to also be able to use our B&O speakers which are attached to the existing TV.
However, we're not massive TV watchers (normal tv programmes and the odd netflix film rental) so don't really want to run to the expense of a new set.
Our ideal TV would be 48-55" screen size, few hdmi inputs, ML compatible and an expected life with light use of (say) 5+ years. Our max budget would be around £2000.
Which used/pre-loved TVs would you recommend, Any further recommendations of 2nd vendors would be helpful as well to avoid the ebay lottery.
Alan
