Turning Beo4 off 'TV' mode
So I've done this before but I've completely forgotten how to do it!
Basically, I bought a used Beocenter 2300 and Beo4 that were being used with a MX7000 TV. I don't have a TV and the remote still thinks there is a TV, so the BC2300 won't respond.
I've reset the remote and that hasn't worked - I remember there is some option that needs setting when you use it with a TV. If anybody could jog my memory that would be much appreciated!
Cheers, Jon
At a guess the 2300 is set to option 0 - you need to change it to Option 1.
On the Beo4, press the red dot and LIST at the same time. Press LIST then till OPTION? shows on the screen. Press GO. Then press LIST till A.OPT shows. Press 1 and the 2300 should blink and will then accept codes from the remote.
Great - worked perfectly. I see how you 'add' devices know - awesome.
