Turn Beosound Ouverture On/Off Using WiFi?
soloAudio wrote:
Here are the details of how I solved this. I hope this is helpful for you.
Hi Tony,
Please confirm I've understood you well:
What you did is an IR blaster sending Beo4 streams, running a little web server you can control over network?
If it is so, I got a couple of questions for you:
- Could you add more controls. Like source selection, CD/track selection, Channel Selection etc… Would this be easy or complicated.
- From where do you take (lear) the IR controls? (related to the previous question).
- Could this work with non B&O equipment? And mixed brand (like Samsung TV with B&O sound system😕)?
I feel like they could be very funny and useful things to do with this, dont know precisely what just now, but it opens possibilities.
Thank you.
Hi Tony,
[Tony]
Yes, that is correct (as originally stated when this thread was started). It is just a WiFi controlled Beo4 emulator.
[Tony]
This would be “easy", given you have the right control sequences by extending the beo4_cmds table. I did have some problems (see Caveats/Issues), so more experimentation is needed.
[Tony]
From various places. Anywhere I could actually. It was hard as there isn’t just one released reference. B&O doesn’t seem to want this information distributed. Many build receivers, and reverse engineer their RCs. In any case, my only goal was to turn the Ouverture on and off remotely, and wasn’t interested in a complete Beo4 replacement (at least not initially, but I do think it would be fun to keep extending it).
If you just search, you’ll find all kinds of references, and similar work done long ago. Here is just a few that I found:
[Tony]
I don’t see why not. It would be a matter of re-configuring the RMT feature to use a different carrier frequency, and probably a different representation of pulse code modulation (bi-phasic coding, pulse distance coding, etc.). A different emitter would be needed (or one that can handle a range of frequencies, depending on how many other non-beo devices you wanted to control). An app button that switches the display to a different device would be used to initiate the reconfiguration, or each app button could uniquely indicate the device, etc. For me, everything I have now already comes with an app and already has WiFi support, so only my antiquated B&O Ouverture was an issue for me. But yes, I think such other projects are totally doable.
Thank you.
[Tony]
Yes, I totally agree. The device also includes Bluetooth and BLE, as well as a variety of physical buses, so we are only limited by our imaginations! ;)  Good luck!
Thank you Tony for your comprehensive answer,
It sounds like beyond my reach right now (specifically the part with mixed IR protocols) and at the same time very exciting. But anyway the door is open and i'll keep that somewhere in a corner of my mind for later.
Thanks again for your work and the knowledge you shared.
Hi Tony,
thanx for your great work! Is there a way to send hex or raw code ?
I got this code (Bemooster 7000)
Radio:
1908FF000001001605003502DF00350F10003505EA003508F800350C05000001000202020202020
20302000202020202030404
CD:
1908FF000001001605003602DE00360F0F003605E9003608F600360C03000001000202020202020
20302000203000203000404
Phono:
19080082000500130C00320061004C008E004C005E0072002600260026004C01100026008800320
1C700370026003200C1009C00440076390D00010201030402050504060703080801090A0B
AUX:
190800820005000E0B005C003D00310058005C00F3005C009300310098004F0026005C006100260
0A800310076002600260031390E000102030405050607010809050A
Laut:
1908FF000001005506003002DD00300F11003005E9003008F700300C03003021990000010002020
2020202020300030200020202020405000001000202020202020203000302000202020204000001
000202020202020203000302000202020204000001000202020202020203000302000202020202
Leise:
1908FF000001005506003002DE00300F11003005E9003008F700300C03003021990000010002020
2020202020300030200020300020405000001000202020202020203000302000203000204000001
000202020202020203000302000203000204000001000202020202020203000302000203000202
Mute:
20300020202030200030404
Input Phono:
190800820005001A0E00350046003500CD00260053006B003D00350027002600270026003B00260
0F1006B006B006B00A40035005C006BFFFB0035007A003539080001000002030400040506070803
040904080A0B0C030105030D
Input AUX:
19080082000500130E00320065004B009C004B0062007000260026002600D40026009600E000320
09500570026007200D10032004A003D00260072009F003239060001020103040005060707080109
0A0B0C030D
Input V AUX:
19080082000500110B002F004F002F00D4002F00760045008900570026002F002E0045005B00260
05600A701E200A700B4002F3902000102030000040401050605070108090A
Power OFF:
1908FF000001001605003402DE00340F11003405EB003408F800340C05000001000202020202020
20300020202030200020404
Input Tape:
1908FF000001001605003502DE00350F10003505EA003508F700350C04000001000202020202020
20302000203000202030404
Input Tape 2:
1908FF000001001605003602DD00360F0F003605E9003608F600360C04000001000202020202020
20302000203000300020404
0:
1908FF000001001605003502DE00350F10003505EA003508F800350C04000001000202020202020
20300020202020202020404
1:
1908FF000001001605003502E000350F10003505EA003508F700350C05000001000202020202020
20300020202020202030404
2:
20300020202020203000404
3:
1908FF000001001605003502E000350F10003505EA003508F800350C05000001000202020202020
20300020202020203020404
4:
1908FF000001001605003502DE00350F10003505EA003508F600350C04000001000202020202020
20300020202020300020404
5:
20300020202020300030404
6:
1908FF000001001605003502DF00350F12003505EA003508F800350C05000001000202020202020
20300020202020302000404
7:
1908FF000001001605003502DD00350F10003505EA003508F700350C05000001000202020202020
20300020202020302020404
8:
1908FF000001001605003502DF00350F10003505EA003508F600350C05000001000202020202020
20300020202030002020404
9:
1908FF000001001605003502DE00350F10003505EA003508F700350C05000001000202020202020
20300020202030002030404
Hi Tony,
Radio:
CD:
Phono:
AUX:
Laut:
Leise:
Mute:
Input Phono:
Input AUX:
0A0B0C030D
Input V AUX:
Power OFF:
Input Tape:
Input Tape 2:
0:
1:
2:
3:
4:
5:
6:
7:
8:
9:
