Tuning BS3 with Sony Bravia
Hi All,
This could possibly be a replication of an earlier post, so i apologise in advance if that's the case.
Can anyone offer some guidlines or pointers in tweaking a BS3 for use with a Sony Bravia LCD.
Thanks,
Ash.
P.S. B&O screen is not an option at this point in time, but don't think i've not thought about it ;-)
Im afraid you cannot do this and if you do the results will be significantly worse than if you just use the sony as a standalone.
The BS3 is more of a hinderance than a help unless you pair it with the commercial series of panasonic panels
I am using my sony bravia XBR LCD with Beosystem 3 without any problem. Picture quality is excellent and I am even able to turn the tv on/off with beo4 remote. Please explain what problem you are having when conncecting sony to BS3.
My query was relating to any fine tuning settings you may have changed when first installing the BS3. I already have the Bravia and the BS3 will arrive later in the month. After hearing from my dealer that it will work okay, 'with some tuning', i was curious to hear feedback from other members as to what the picture settings they used to achieve a good quality picture.
I'm not expecting the BS3 to improve what i already have, just to integrate it into my B&O speaker environment.
My dealer recently performed a software update to my BS3. After the software update, I wasn't able to get picture on my sony screen. After a long run around someone from beocare called me and walked me through changing some setting in the service menu. If you run into same problem give me a pm.
Will do, thanks for your help!
