I plan to use my new BeoPlay in a way that streaming radio can be started via the device directly rather than using a smartphone. Device is a BeoPlay A6 with current firmware 1.7.449.214258016 and the following behavior:
TuneIn login is configured for the A6 so that the device can access TuneIn's favorite list. When I plug out (cut off from power) and plug in again the device and activate the device with the On/Standby soft button, a stream of the favorite list starts to play automatically after a couple of seconds. Great. This shows login for TuneIn works.
If i set the A6 to Standby (via Activate/Standby Button) and activate the device as before, no stream is being played. It seems that sometimes the ">" Soft button seems to help, but normally the A6 goes into standby again when this button is being used.
Therefore playing a TuneIn stream via the A6 directly does not work (except power is being cut off before).
Anybody with the same problem or a solution available?
