Carolpa wrote:
Looking at the pictures I presume BLC were used as “active speaker kits” and the MCL/ML or BeoLink Passive as amplifiers.
Agree. If there are really 4 (!?) NL/ML converters, they all should appear in the Beolink app...
BL passives work as amplifiers (like MCL2P) connected to Powerlink outputs of the 4 converters, and IR receivers also connected to NL/ML converters.
Tom, can you take a photo of the connection panel of one of the converters?
And first I would check:
- do all converters hve a green light on on the backside?
- Do all BL passives have a red light?
- Do all IR receivers have a red light (standby mode)
- check if there is a Powerlink cable connected between each converter (RJ45 output) and BL passive (8 PIN DIN plug)
- check if there is an IR cable (white, thin, RJ45) connected between each converter and one IR receiver.
Stefan
