I bought a CD5500 which has stopped working, actually it was a wee bit intermittent from the off. Basically, I heard it play when I bought it, we then travelled home and it didn't work, but after a short while it started to work. I then moved it in the living room and it's stopped working again.
Now when I say it doesn't work, I mean it powers up, CDs load, the display shows 'track' but that would be it. So, I've changed the capacitors bought from Dillen, but that hasn't worked so where do I go from here.
I can't help but think it might be a physical problem, maybe loose connection, crack or something.... any ideas would be great....
Cheers,
Tony
