Im going to be picking up a BV7 on motorised stand with 7.1 in a few days and want to know how best to transport it and what I have to do to get the stand/speaker off so it fits in the car. Its a big car (volvo estate) so space shouldn't hopefully be a problem but what tools will I need to dismantle the thing and is it easy to do. Im presuming the panel needs to be kept upright, is that correct.
Transporting a BV7 help.
Hi R,
Take the panel off the stand and the speaker to. I've always moved BV7's screen up on their back with plenty of padding underneath and all has been ok so far!
Cheers
Thanks for that, any special tools needed to remove the the screen and speaker from the stand?
anyone?
Anyone? I need to know how you remove the screen and speaker from the stand.
Just an allen key. size err mine says 5/32"CR-V if that helps. Oh it also so fits in the hole that says 4 on my key set. ;-)
