and i´m so happy as i´m looking for a new beolab 2000 for a while...
Excellent! - is it for a bedroom, bathroom or somewhere else?
Hi every one,
This is my fist entry to Beo world, i also bought a Beolab 2000 on ebay last week, and am hoping to link it up with my BS3000, The Beolab will be put in the Kitchen.
Do i just need a power feed ???, and a Master link connection to my BS3000.
I am looking at putting a master link cable around my house, for future equipment, do i need just to break into the cable and put a junction box in at various point around the house. And would it be easier to buy the cable with the plugs on all ready, and put a Junction box to extend the other ends of the cable, as it is hard trying to put a master link end through a 25mm hole.
The lab 2000 is a great link machine.
I used to have one in the kitchen, but sadly I sold it.
All you need is power and a ML cable.
Thanks for the congrats.
I´m gonna use my new Beolab 2000 in our (small) foyer.
Thanks very much for your advice craig.
I hope to set the unit up in the next couple of weeks.
Do you know where i can buy the ML leads with only one end. Boss com perhaps ????.
B&O can supply them like that - The easiest way is to just splice into the existing ML and solder the connections rather than using a junction box. You just have to remember the short out the pink/blue and white, as the junction box does this for you.
I heard Bosscom have gone bust and made to destroy all their stock due to a copyright lawsuit so I think you may struggle to buy from them now.
Hope this helps,
Llewelyn
