Hi mbolo01
I suppose there is not much traffic at the time of the event? No...
You can't compare your fault with mine I had this morning. This morning there was a sudden loose of music immediatly following with a disconnect/connect of IP-address to the Moment, it happens somewhere in the middle of a playlist just about when the Moments would start a new track.
First serious disconnect after last weeks update, there was no traffic, not a clearing of the DHCP lease... Immediate checking all logs on router, AP's and server showed me ... nothing suspicious! But it was a serious incident, something just kicked the Moment out of the network.
I found a problem on the ML/NL converter, so it looks my cause was coming from the ML/NL converter who suddenly shuts down the Moment without any reason, nobody touched anything! 😠
Extract of the log when it happened:
Mar 15 10:01:25 (none) fpsd:
GST.salsautilsink: ALSA wait error, -32 [gstsalsautilsink.c:436, 3101.473]
Mar 15 10:01:25 (none) syslog-ng[541]: Last message 'fpsd:
GST.salsau' repeated 2 times
GST.salsautilsink: Retrys did not help, bailing out [gstsalsautilsink.c:487, 3101.473
