To Days The Day :-) The New Avant...What Do you Think Of It?
Bno really needed to come off the blocks like speedy gonzalez on this one , instead they seem to have crashed and burned.
New avant ? give me a break
I think they where quite quick in temporarily stopping production to look into the problem. For car manufacturers (as an example) it takes sometimes years to do the same.
in the meanwhile B&O can churn some extra BeoRemote Ones for retail ๐
yes ... and I even tried buying one on Saturday - but they had no part number by which to order
(should be a shelf item !)
I like it, but I wish it was as "solid" i.e. heavy / hefty as the Beo4
SWMBO is concerned she won't find the right buttons in the dark ....
Itยดs very notably when watching a football game where half the field is in bright light and half is in shadow. Keep us posted!
There actually is a part number for BeoRemote One, but the dealers' ordering system prohibits sales of the remote separately. Now that at least BV11's software has been updated to support BeoRemote One, it's a pity they don't sell it.I heard that there might be a steel version of the remote. Steel is heavier than aluminum, so perhaps customers will eventually have the option to choose which feels better: a lighter or a heavier version.I want it first and foremost for the new & handy way it handles sources and functions: I have 14 sources as of now in my setup (including separate audio systems), and I dislike the prenamed buttons of Beo4. They don't have the right names for the sources. With BeoRemote One, it's possible to have the correct names for sources as any source can be renamed. It does not bother me that they'll be soft-buttons behind TV and MUSIC.Since Beo5 is a pain to configure & modify, while waiting for BeoRemote One, I'm mostly using PolyMote for iPhone (for BV11 & connected sources), together with the controls of music apps I use for AirPlay through BeoPlay A8 and Playmaker.So effectively, iPhone is my all-in-one remote until B&O releases BeoRemote One, which I'd much rather use โ hopefully soon.To get this back on topic, I envy the early adopter Avant users for their superb new remote ๐yes ... and I even tried buying one on Saturday - but they had no part number by which to order (should be a shelf item !) I like it, but I wish it was as "solid" i.e. heavy / hefty as the Beo4 SWMBO is concerned she won't find the right buttons in the dark .... The Essence of B&O is discretion in design and life
Register to access the forums, reference material, and exclusive member benefits โ including our monthly prize draw.
