Theatre failure. Help needed.
Hello Beoworlders,
While looking at the TV, my Beovision Theatre suddently turned off making a huge crack sound.
I power-cycled the set but nothing happens. No light on the control panel and the Theatre appears as offline in the B&O app.
The LG TV works with the LG remote, but does not react to the BR1.
Is there somewhere a switch to reset the Theatre?
Thanks by advance,
Yann.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
Sounds like you have a power supply failure
Bang & Olufsen classic service centre.
Repairs and refurbishment to both old and new.
Hello,
That’s what I think.
The problem is that my dealer closed one year ago, I’m 300 miles from the closest one and I doubt that a tech would come to my home to repair the set.
Is there an easy way to remove the screen (or ideally the soundbar) from the soundbar/stand/screen assembly?
Kind regards,
Yann
Hi
contact a dealer (its possible that you have a authorized technican in your area even if the dealer have closed)
I reached out to product support, hopefully they will let me know the local repair technician for you.
Thank you to help me.
I did the same through the customer assistance.
A tech from B&O called me, the issue is in the pipeline.
I'll keep you posted.
Kind regards,
Yann.
Thanks Oli.
