When it came out I bought a later B & O remote, can't remember the model though. It had a glass display and buttons on both sides. Hopeless! Thank goodness I still had the 1000 at that time.
Yes the BeoLink 5000. That's what i had, but the insurance company replaced it with this BeoLink 1000. 🙁
I didn't know so many people STILL liked it > It would have been amazing in its time, but for masterlinked TV's with motorised stands and set top box controllers, it's very backwards, and makes operation, an unpleasant experience.
The Beo4 is absolutely brilliant. You comfortably hold it where the center of gravity is, and everything you need is in easy reach with just your thumb.
That is my problem with the BL1000... you have to look at it and the buttons are all over the place. The play / stop / up / down / left / right cluster on this remote is barmy! You have to repeatedly press << >> in order to turn the television. What is the deal with that?
Not having an EXIT button is also a daily nuissance.
So basically i'll be selling it. I'm sure it'll be useful to someone who has B&o from the time it was designed.
