The unique, one and only SOFTWARE UPDATE THREAD!
Raeuber You gote MSG .
The new version 0.1.8.9.0. in my DVB HD T2/S2/C, give me problems with my CI + module and SmartWi Card Splitter and Comhem. When I installed the old 0.1.7.2.0. again, it worked.
I have a BV10 and Comhem as operator. I have HD via their CI+ module. No card splitter.
I was going to upgrade tonight but now I gor reluctant. Was the problem you encountered due to your card splitter or is it the HD-module that does not work with the new SW version?
I did not test with the original card from Comhem.
But only with SmartWi Card Splitter.
Started to mess immediately
Worked for a while, then error that it could not decode
Pulled out the CI + module and then back, then it worked for a while. Then it started to mess again.
Flashed back version 0.1.7.2.0. And then all the problems disappeared.
Have run with version 0.1.7.2.0 since last Friday, and everything has worked cleanly.
So the latest version seems to contain new bugs.
I have found another great bug in software 0.1.8.9.0:
It is not possible any more to add channels in channel-groups. After adding the channel with the yellow key, they are not stored in the group after pressing GO.
So I have downgraded my DVB-HD-C module to 0.1.7.1.0.
It´s a shame, B&O!!!
/Räuber
Also could not add any new programms to any channel groups. I have downgraded to 0.1.7.1.0 and the system runs well. Again I`ve upgraded to 0.1.8.9.0 and the same problems appear again.
For sure I will run my BV with 0.1.7.1.0 till the next software update.
Also with 0.1.8.9.0 I now have no closing curtains. Just a 20 second wait then sudden shutdown.
David
BV8-40
I'm at 0.1.8.9.0 and my opening and closing curtains work just fine. Have you tried rebooting the DVB-HD module? In my experience, a reboot sometimes works wonders after an update. :-)
ks!Hello
How Do I downgrade to software 1.7.2.
Thanks!
