i have a BV-7 32 ( so NOT a sys 3) when i was sold it, the dealer, ( Thats you Mr Kinsella!!) told me that an upgrade for freview HD would be along....hows this getting on ?..or isnt it ?
andy
andy
a new update for the HD mudule is available on B&O website (V. 0.1.8.9.0).
The only news I have recognized is in the EPG menue (green key): In the upper half of the screen you can see now the picture of the current program. The startup time is still more than 30 seconds.
Regards
Räuber
Regards
Räuber
Thanks Räuber!
I've just uploaded it to the BV10.
Is it me or are there new menus when you press menu Options + 0 0 Go from the beo6?
Cheers,
Hi EdoiardG,
yes there are further menues if you press 0 0 Go, but I didn't try this with the older software versions so I don't know if this is new. P.e. it seems possible to transfer the settings to an usb stick or to transfer them back to the hd module. Did you test this function yet?
/Räuber
Frankly, I didn't dare [:'(]
But now, I don't remember what I did to see that menu you're talking about.
It's not the advanced menu nor the customer menu.
I remember I've seen a menu from where you can set the internet settings too but don't remember how to call it.
Could you please tell me how you did to call this menu?
Cheers,
PS: Why is this update 0.1.8.9 and not 0.1.7.3 as the previous DVB HD update was 0.1.7.2 ? Weird !
... a new update for the HD mudule is available on B&O website (V. 0.1.8.9.0).
V. 0.1.8.9.0 offers bug fixes for several issues in different markets and a "semitransparent" EPG.
- Press MENU (only once for the menue of the HD module)
- Select 4 (EINSTELLUNGEN in german)
- Highlight OPTIONEN
- Press 0 0 Go
Now you see the service menue of the module, I recognized it yesterday for the first time, so I don't know it's new in 0.1.8.9.0.
Cheers
Räuber
Thanks Räuber!
I didn't notice this menu before, maybe something new?
Did you try to connect the BV10 to the internet?
Cheers
- Press 0 0 Go
Cheers
Räuber
Thanks Räuber!
Cheers
No, because I have not a long enough cable (my router is far away from my BV 10-40) and the internet connection is only for update purposes of the HD module which can be also done with an USB stick.
/Räuber
The new version 0.1.8.9.0. in my DVB HD T2/S2/C, give me problems with my CI + module and SmartWi Card Splitter and Comhem. When I installed the old 0.1.7.2.0. again, it worked.
