BeoVision 10 just got a new build 165 and it's screaming fast (compared to old sw). Boot time with DVB-HD is now half what it used to be, fantastic!Is this the DVB-HD T/C version 0.1.6.5.0 update that is available on link ?
Does any one know what changes this version contains, and if it will reset your channel settings after you run the update?
Hi metalmickey,
no, build 165 is the software-version of the firmware of BV10. It can only be updated by your dealer.
The update-version 0.1.6.5.0 is only an update for the HD-module, that can be installed by yourself. After the update channel switching is a little bit faster and you can also update the infos in the EPG by pressing the blue key. Your channel settings will not be reset by running the update.
/Räuber
