The unique, one and only SOFTWARE UPDATE THREAD!
metalmickey wrote:
akoro wrote:
BeoVision 10 just got a new build 165 and it's screaming fast (compared to old sw). Boot time with DVB-HD is now half what it used to be, fantastic!
Is this the DVB-HD T/C version 0.1.6.5.0 update that is available on link ?
Does any one know what changes this version contains, and if it will reset your channel settings after you run the update?
Hi metalmickey,
no, build 165 is the software-version of the firmware of BV10. It can only be updated by your dealer.
The update-version 0.1.6.5.0 is only an update for the HD-module, that can be installed by yourself. After the update channel switching is a little bit faster and you can also update the infos in the EPG by pressing the blue key. Your channel settings will not be reset by running the update.
/Räuber
A new softwareupdate, version 0.1.7.1.0, for the DVB-HD module is available at
Thanks for the info!
But the update doesn´t work. I have tried to install it on my BV 10-40 (build 166, HD-Software 0.1.6.6.0), but after pressing the green button it always shows "no update available". I have tried it with different usb-sticks, but no chance.
I had already updated the software of the HD module several times, always without any probs. So I think the update files are faulty.
Has anybody made a successfull update??
Regards
Räuber
I just updated my Beovision 8-40's DVB-HD without any problems.
I had problems with the updated last time, but today it worked just fine.
Do you have the T/C- or the T/C/S2-HD-module?
I have the T/C version
Me too, I don't know why the update is not possible with my BV 10-40!?
Meanwhile I was successful by updating in another way:
- connect the stick
- pressing DTV
- screen goes yellow
- waiting until the screen turns green
- disconnect the stick
- standby
- disconnect from the mains
After this procedure the module info shows the update version.
Did you recognize any changes?
Regards
Räuber
I've heard that the newer BS3 software updates have dropped the ability to turn on/off non-B&O plasma/LCD displays.  Anyone know about this?
-- Paul
Has anyone seen an update for BeoSystem 3 / BV 7 recently and do you know what the updates contained. In particular, I'm looking for improved handshake functionallity over HDMI for AppleTV2 and Sky Box. I'm currently running 10.02.
Also - on a seperate note, has anyone seen a more recent Blu-Ray software update for the onboard Samsung drive on the BV7. Unfortunately I have a BV7-40 MkIII which requires a manual firmware upload. I currently have a build dated back to last April.
Thanks all.
