The unique, one and only SOFTWARE UPDATE THREAD!
Hi!
Have you noticed any other differences?
I have build 153
br
/h
akoro wrote:
BeoVision 10 just got a new build 165 and it's screaming fast (compared to old sw). Boot time with DVB-HD is now half what it used to be, fantastic!
What build did you have before the upgrade to 165? 🙂
I had Build 153 before update.
Some small change in game mode settings and auto standby works also with audio only. So you can connect ipod to camera and tv will not go into auto standby if there is audio present.
Where can we download these updates please ? And how to apply them on the BV10 ? Same procedure than for DVB-HD module update ? Where do you get the actual release info in the TV ?
That type of update has to be done by a service technician. B&O do that for free if the update address a problem that you experience. Otherwise you have to pay for the man-hours spent.
anyone know what the latest SW version is for BeoCom 5, how to check which version you have and if all problems has been resolved with the call quality on it?
thanks
Klas
2.10 is the latest sw version.
*#1234#and there you go🙂
Mine was bought in Jan2011 and has the following.
Handset 1.7 from 26.1.2010
beoline2 Base 2.1 from 16.11.2010
Heribert
my bs3 has been updated with 10.05a SW
apparently no more dark screen issue ..[UPDATE]>>>>>still dark screen issue!!!! :( :( :(
now it handles togheter  apple tv + ps3(both in HDMI) on PinP function!On previous version,didn't work(one screen were always dark).
Is this the DVB-HD T/C version 0.1.6.5.0 update that is available on
