The unique, one and only SOFTWARE UPDATE THREAD!
This is mine (BV10-46):
TYPE NO. 9565
BUILD: 155
PW328: 04.05ef
FEP: 04.03fc
FEP BOOTLOADER: 00.03b
FA MODULE: 00.02.02
STB TABLE: 05.56b
SYSTEM MODUL: 20.06f
SM HW: n/a
BtB Module: n/a
DSM FEP: 05.18a
DSM DSP: 05.15a
DVB HD: 0.1.5.8.3
TCON: 20091123-230839
Hi brulz,
interesting that your DVB HD module has the version 0.1.5.8.3.
On the B&O website you can still download the version 0.1.4.7.
Does anyone know where you can download the actual version?
Regards
RΓ€uber
What is the latest software version for the Beovision 10-40?
/C
Beovision 10-40/46 MKl / MKll (typ 9570, 9565 / typ 9572-9573, 9566-9567)
Automatic Software Update     : Build 155
DSM FEP Software Update       : 5.18a
DSM DSP Software Update       : 5.15a
System Module Software Update : 20.06f
PW328 Software Update         : 4.05e
FEP Software Update           : 4.03f
Raeuber wrote:
Hi brulz,
This is a beta version that the b&O give to my dealer (Italy - Brescia www.hitech-audiovideo.it) for testing πŸ˜•
Thanks Talisman!
How does this with "build" work?
Is "Build 155" the revision of a package that includes the other software components you list?
My BV10-40 is on Build 127. Not 100& of the other software components you list above have stepped up the revision, but many.
Do you happen know what problems that has been addressed between Build 127 and Build 155?
"Do you happen know what problems that has been addressed between Build 127 and Build 155?"
I actually found the answer in the Forum, at least between 127 and 153: πŸ™‚
http://forum.beoworld.org/forums/p/36070/299193.aspx#299193
Hi BS3 and BV7 owners,
Who has upgraded to 10.02 so far? Has anyone had any problems with this particular build? I'm hoping to schedule my dealer to visit me this week, but before I finalise it, I just wanted to check that no new bugs had been experienced out there. I currently have V8.0x installed which has been fairly robust (touch wood.)
As I have a BV7-40 Mk3 with the Blu-ray installed, I'm especially interested in getting any Blu-Ray drive updates, since I'm unable to do it over Ethernet.
Does anyone have the detailed technical update overviews for 10.02 and 9.01 by any chance from the service tool?
The primary reason for this update is that I have the new Beo4 with joystick and want to use this feature!!
Thanks in advance.
Hi
I have a 7-55 with BR, and got the 10.02 installed before christmas, and it is stable.
2 times I have experienced that the red light was blinking, but that was before christmas. B&O have made a fix for that issues now, something with the DVB-HD.
I can recommend the 10.02.
Br.
BeoVision 10 just got a new build 165 and it's screaming fast (compared to old sw). Boot time with DVB-HD is now half what it used to be, fantastic!
