The unique, one and only SOFTWARE UPDATE THREAD!
Hi, I have a Beovision 7-55 and have upgraded my software to 9.01. I experience a problem whith the contrast. When I start up the TV the contrast will go upp at maximum and after 1 minute it will slowly go back to normal. I didn´t have this problem with software 8.12. Does anybody else experience the same problem?
My second question is if SW 9.01 is the latest software?
Regards
Latest available soft ware 2010.10.12:
BEOSYSTEM 3MK 1, 960X-961X & BEOSYSTEM 3, MK 2, 9615-9628 :
Version 9.01/build 714
Hello Peter and Svend fans,
I got build 153 today for my BV10-40 after an intervention of my technician.
First noticable change : the beo4 "with navigation wheel" works like a charm with my french cable tv set top box (Numéricable).
No more go + up or down, only up or down to change channel.
Didn't have the time for more investigation !
Cheers,
Gregory
SW 10.02, build 8.14 for BS3 televisions is now available.
Fix a lot of issues on BV 7 including MY problem with 24p material :-)
Furthermore fixes an issue with the tv dimming after a while.
Introduces the possibility to deactivate centerspeaker.
Delays the fans for 20 sec. to let the tv start up and cover the fannoise. before they start.
Other issues has been fixed aswell
/Ehlerz
ohhhh anything else important to note.
My build seems to be fine for me but its always interesting to note what changes have / can be made.
Seanie
I got the update today.
it fixed the modulator bug introduced in fw 9.01. In fw 9.01 the modulator didn't switch on when a video source was selected in a link room with a BeoLink Active.
msinn
After a service my 1 year old BV8-40 got build 153 with DVB-software 0.1.4.7
But it changend only a little regarding the "fan noise" of the DVB-module after round 45 min.. Also have the problems with "something like transpartent shadows by movment" round people on the sreen. They seamed like cutted out.
I have never had the problems with my BV8-32. Even the sound of the BV8-32 is much better (have both placed side by side).
Thanks for this mbee.
I can't find a listing for a BC6-26 on the first post, so here are the details for mine (2007 model - type 9282). It has not been updated since I bought it new.
Monitor :-
AP SW 9.2.
IOP SW 22.0
STB table 3.8
TV-Tuner:-
Doesn't seem to state a SW version.
Radio:-
FM SW 1.0
DAB SW 1.9-4
Are there any updates available that might be useful for me and can I do it myself?
Thanks very much
BeoCenter 6-23MKII/26 (Type 9219-9226, 9280-9287)
Latest Software 10.10A
Thanks.
Mine is a 9282 so would that sw version be correct?
 Any idea of a changes/benefits and cost of an update? Is it a local dealer job or is there such a thing as a B&O specialist who is not a main dealer?
