I would second that suggestion. Excellent idea.
The unique, one and only SOFTWARE UPDATE THREAD!
Does build v127 for BV8 includes both the BV8-40 and BV8-32 ?
Thx
how can I tell what software version I have in my bv8-40?
Hej
Som jeg læser det (se nedenstående), er det så korrekt, at der er kommet en ny opdatering til BV10-40 dvs. version 0.1.4.7 (jeg har lige tjekket og har nemlig version 0.1.4.5 og vil derfor gerne lave en opdatering til den nye version) , og er der nogle der kender changelog?
Mvh. Knud
DVB HD (MKI/MKII) module (found on BV7, BV8 and BV10) : latest version :0.1.4.7 - 11/06/2010
This software update can be done by the user : download it here : http://www.bang-olufsen.com/dvb-hd/software-downloads
0.1.4.5 - 12/05/2010
BV7 and BV4 have this!!!
MY BV9 for 22 000€ does not work with my new Beo4!!!!!!
Whats the problem Struer??
I have update mu BV9 to 9.01 now...BUT why is there not any option to use Beo4 MKII???? BV7 and BV4 have this!!! MY BV9 for 22 000€ does not work with my new Beo4!!!!!! Whats the problem Struer??
My BV4 doesn't have that option either. Even with 9.01.
My BS3 is MKI i don't know if that is why.
/Weebyx
I think you need hardware uppgrade, check in customer menu if IOP SW is below 23.00 (early BS3MK1 and BV9) if so, that is the problem
and you have to change AVS/H8 module
/Tompa
how much for that module??
I don't now price for it, but call your local B&O service for price
/Tompa
This thread really should be pinned. It's more useful than many of the pinned threads.
