The unique, one and only SOFTWARE UPDATE THREAD!
Hi Räuber,
thanks! I agree , it must be the same. But what does your versions relate to in terms of software version?
Was it updated to 1.09e?
Thanks, Peter.
Dapper wrote:
Hi Räuber,
Thanks, Peter.
Hi Peter,
yes, my BV10-40 was updated to software build 109e from 26/04/2010.
/Räuber
martin01 wrote:
Which is the latest software for Beosystem 3 (or Beovision 7-55, Beovision 7-40 w BS3)?
Hi Martin,
I created this thread to answer this kind of questions : look at the very first post of this thread (page 1, post 1) : everything I got about software updates is there. So the latest software version of BS3 is 8.12a!
Just updated the first post : software build 126 is now released for BV10 and BV8!
If somebody somewhere has a changelog, it would be highly appreciated ;-)
One of the biggest change seems to be the compatibility with the new SAT tuner for BV10/BV8 : DVB T + C + S.
Edited : first news about the changelog of build 126+127 for BV8/BV10... Seems like an interesting piece of software...
I had my BV8-40 updated to build 127 yesterday.
It's a very nice feature that you now can name your sources.
But the best thing is when the TV starts up. Not the hidious clock, but a small Bang & Olufsen text comes on in the right bottom corner. When the DVB-HD is ready, the Bang & Olufsen text fades away, and the curtains open WITH TV picture!!! This is how it should have been from the start!!!
Have tried to add a couple of pictures showing the Bang & Olufsen text. Sorry for the bad quality.
Regards
Claus
foto 2
Great :-) Looks really nice with the logo instead of that silly clock.
Did you update it yourself, or did you have your dealer update it?
I want this update for BV10 :-)
Hello guys,
I was also very happy after update my BV10-40 with software build 127. But only for one day! Then the HD module was gone (n/a in service menue). Factory reset of BV10 didn´t help. My dealer send me an instruction from B&O for reactivate the HD module, also with no sucsess. After my holiday the HD module will be changed, the BV10 has to be put off the wall for replace.
After seven month owning the BV10-40 I must say: never ending horror story!
Because timer recordings with my DVD2 from the HD module are not possible, I bought a HDR2 two weeks ago (with actual software 3.60). But the HDR2 stops working during records with no reason. I don´t know because of a failure of the HDR2 or the BV10-40.
I remember the year when I got my avant in 1998: No problems for twelve years with this nice TV.
Regards
Räuber
My dealer updated it.  🙂
