Hello!
Again a new software (0.1.4.7) for the HD-module was released. You can download on B&O-Homepage!
I couldn´t notice any changes compared to 0.1.4.5 (also the bug in radio-mode was not fixed).
Regards
Räuber
Hello!
Regards
Räuber
Hello!
Regards
Räuber
As far as i know, a bug regarding recording directly from EPG to HDR2 has been fixed.
/Ehlerz
Hello!
Regards
Räuber
/Ehlerz
After update my BV10-40 with the actual software (build 109.e - 26/04/2010) the RECORD-button doesn´t work anymore, so direct recordings from the HD-module and also from the analogue tuner are not possible anymore. Can anybody confirm this bug?
Regards
Räuber
Hello!
Regards
Räuber
I see that this update isn't available on the Danish version of the B&O homepage - I guess this means that it's not compatible with Danish televisions/televisions located in Denmark? Has anyone from Denmark tried this update on a Beovision 10?
I found the update on the German and the English site:
http://www.bang-olufsen.com/dvb-hd/software-downloads
It's here:
I have upgraded my BS3 with this SW and it works fine, just make sure that you read this statement on the B&O homepage, you need to contact your dealer if you have one of these "issues". My BS3 serial number was lower than the required, and i asked my dealer, and all he could say was that it is the SW version in the BS3, so for all the people out there with an BS with lower serial number AND the original SW, the BS3 should be upgraded before using this update.
Hello!
Regards
Räuber
/Ehlerz
Hello Ehlerz,
although I have updated my HD-module to 0.1.4.7, I have a problem with EPG recordings from the module to HDR2: I deactivated the analogue tuner of my BV10-40. In this case a programmed timer-recording is shown in the timer-index-menue of the HDR2, but source is V.AUX, so no record will be made. Only when I activate the analogue tuner, the correct source (DTV) is stored in HDR2 and the recording is correct.
Can you confirm this bug and is there a solution?
Regards
Räuber
my BV10-46 was shipped with this current software:
PW328 0336f
FEP 0314c
SYS MOD 2005R
TCON 20091123 <-- is this the software build date?
Whats the verdict? Is this an older build or the the quoted figures refer to a BV10-40? Or are both models using the same software?
Thanks, Peter.
PW328 0336f
FEP 0314c
SYS MOD 2005R
Thanks, Peter.
Hi Peter,
my BV10-40 was updated a few weeks ago and the software is as follows:
PW328: 03.36f
FEP: 03.14c
FEP BOOTLOADER: 00.03b
STB TABLE: 05.28b
SYSTEM MODUL: 20.05r
BtB Module: n/a (don´t know what it is)
DSM FEP: 04.23a
DSM DSP: 04.19a
DVB T/C: 0.1.4.7
TCON: 20090723 (?)
So I think both BV10-40 and BV10-46 are using the same software.
Regards
Räuber
Which is the latest software for Beosystem 3 (or Beovision 7-55, Beovision 7-40 w BS3)?
Regards
