Hi Ehlerz
I don't think it's because of the distance (unless you have a villa with more than 50m distance).
By how much should then the Video (and audio) be delayed in your opinion (BTW, it takes a lot of memory and processor to delay a full hd picture)?
You mean it should delay the same as it does for the audio on ML. But then as I described above, the delayed video and audio arrives at the link-TV at the same time when it is played in the mainroom. Now when you have a BV7-40 as a link-TV, this 7-40 has to delay the sound while creating the picture. Then 200ms later the 7-40 link-TV would play the sound and the picture. But this is 200ms later than in the mainroom (and in fact 400ms later than from the wall).
It seems, that all your other TV's either have that very fast picture processor to not having to delay the sound or their picture is not in full sync with the sound.
The sound delay is needed to give the picture processor time to create the picture.
I fully understand what you would like to have, but I think that there is no solution to fit all the different needs.
Hi again, i am not talking about delaying a HD picture, but the equivalent downscaled to SD as the tv already does. Be aware that I am only talking about the old ML system and coaxial distribution, not the future CAT7 solution. SO here is an example. In my case, the linkroom tv´s has no independent delay, because they cant receive digital signals out of the box, and hence does not have to process anything. SO here, the RF output from my mainroom should be the same as the audiodelay to mainroom speakers. IN your case, or the case you describe, be aware that when you use a newer 10-40 as linkroom tv, you will set this up with the delay that suits your DIGITAL DVB-HD input that needs processing just like your mainroom tv. BUT when you watch say a DVD source from your mainroom, this signal is not digital anymore, but downscaled, hence your linkroom tv will NOT need to process it, AND not need to delay the sound. I don't know if the delay settings on the tv´s only apply when the signal is digital, otherwise when you receive the synched SD signal from your mastertv, your linkroom tv will delay the sound, and then make sound and picture unsynced. but if it only applies to digital signals, you will not have a problem on your 10-40 either. IF it delays everything, regardless of digital or analogue, it should be possible to set two different delays, one for analogue (0 ms) and one for digital. SO yes there might be some work in making it work, but i really do not think or hope it is impossible. Has anyone else god an opinion on this, i mean it will definitely be solved when CAT7 is introduced, but what about us with older Linkroom tvs? It would be wise to introduce RF out delay for older linkroom tv´s, while owners of newer tv´s will rely on the CAT 7 distributing everything digitally and process the signals in every room independently.
What do you guys think, am i totally wrong in pointing this issue out?
P.s: Maybe we should start another thread about this issue as i am sure a lot of others could benefit from this as well :-)
/Ehlerz
