Shockingly, that featurelist sounds like they've started listening to people?!
Will be interesting to see how this develops!
Thanks guys, I've edited the first post with this really good news...
Anyone knows what is the latest BV8/BV10 software : I plan to make my dealer come at home in order to update my BV8...
The latest BV8/ BV10 software 2010-05-03 :
* Beovision 10-40/46 (Type 9570,9565) latest software = Build 109e
* Beovision 8-40 (Type 9560) latest software = Build 109e
* Beovision 8-32 (Type 9551) latest software = Build 137
* Beovision 8-32 (Type 9550) latest software = Build 137
* Beovision 8-26 (Type 9500) latest software = Build 137
Is that still the 11/2009 build, or is it a new release?
I visted my local B&O store today, and they told me that the update for BV10 should be available from May 18th. They also said, that if you bring an usb-stick and your television serial-number down to the store, they can transfer the update to your usb-stick and you can thendo the update yourself afterwards.
BeoVision 10 - 40
Latest Tv software versions and release history:
Version Build 109e. Release date 26-04-2010
Version Build 109b. Release date 15-03-2010
Version Build 86b. Release date 28-10-2009
BeoVision 10 - 40
Could a software upgrade resolve a backlight/clouding issue with better settings ?
Am I dreaming ?
Gregory
Where can I find the installed software-version on my BV 10-40? I can only find the version of the HD-module but not of the TV (specially not in the service menue "0 0 GO").
Regards
Räuber
I think your dealer meant the software-update for the HD-module, not for the TV. The software-update for the TV cannot be done by yourself via usb-stick. Or am I wrong?
Regards
Räuber
Regards
Räuber
Sorry, you're right - the update was of course for the DVB-HD-module.
