The unique, one and only SOFTWARE UPDATE THREAD!
Thanks Elephant, added! 😁
mbee wrote:
BS3 (valid for all BS3 based TVs) SW 7.05 (Build 551) - 02/11/2009 :
1. No menu, no overlay menu, no curtains (Build 548).
2. Menus and OSD disappeared (Build 548).
3. BeoSystem 3 freezes when receiving DTV+CINEMA_OFF from standby (Build 548).
4. TV does not go into standby, and standby diode is blinking (slow flash) (Build 548).
5. Intermittently the television switches off (Build 548).
6. ACM crashes when source is YPbPr in High-Definition (was solved in Build 533) (Build 548).
7. No volume bar after using EPG in DVB-HD (Build 548).
8. Panel info says 50 Hz and not 100 Hz (Build 548).
9. No link control of DTV source (STB), if main room television is in standby (was solved in Build 533).
10. Lip-sync on Blu-ray does not match.
11. Timer on DTV-RADIO. Turn on to last shown TV (DTV) channel when link TV is connected.
12. Non B&O screen: Screen switches on when switching off from audio mode.
13. Not correct channel is showed when Play timer from another favourites list is programmed.
14. Difference in sound level between DVB picture and DVB Full-text.
15. Different issues with opening and closing curtains (half open-half closed).
16. Mixed sound from Radio and DVD in link room.
17. Stand does not always turn to stored positions.
Great idear
I have been missing this for a while :-)
I unfortunately have to add, that 7.05 also speeds up the fans with dramatically increased fannoise as a result. (at least on 7-40 MK IV)
Dont know if the updates are intended to be discussed here, or only presented ? If the latter is the case, i apologize :-)
/Ehlerz
Is there any chance that this can be pinned?
I assume it will be very interesting for everybody eventually
Spiros : good idea, but pinning a thread is a moderator's choice...
By the way : I updated the BS5 part with yesterday's software update. If someone can give the full changelog, it would be perfect!
A 7.11 version is coming for Beosystem-3 based TVs. Apparently, the fan issue is fixed according to some "beta testers" from the Beoworld Scandinavian forum.
Regards,
Jean
This post is a very good idea !!!
For BV7-32/TYPE 9312/MKII/
Latest Software is software version is 6.33 with a part number of 8344431. No idea about the improvment made by this software but it should make the TV HdReady.
Source: /forum/general-discussion-and-questions/sw-update-on-bv7-32-type-9312-help-please
Mat
@matbkk : added!
A huge DVB-HD module update will be available in week 14, It should deal with missing EPG information etc.
/Ehlerz
Will that eliminate our evil with the creeping EPG ?
HeKoch
Hopefully this discussion will get pinned.
7.11 is hopefully a significant release. I'm hoping for fixes to the fan issue, resolution of picture quality degradation with 7.05 in both SD and HD versus 6.xx and bug fixes to Blu-Ray drive. I've gone back to 6.11 currently as 7.05 was totally unacceptable and our B&O engineer felt more comfortable with it due to other customer issues he had seen.
