The TV button, what to do with it.
WHAT????????you mean, that when i will upgrade my BS3 software this month,i will see PS3 on the STB list and fully integrated with my beo4????😕
know the feeling -  I must have about 30 remotes in the garage over the years that I've collected, I must ebay them soon and buy a Beo5
Yup you will have to ask them if they have the STB list but it should be ok  😁
My garage is in fact built out of old remotes. I have a Beo 5 and i have a spare Beo 4 but i am keeping that baby.  I also have a draw full of batteries for the EU mountain of rubbish.
What a good news! 😁😁
PS3 slim incoming...
I have had this option for more than a year now on the old PS3.  Glad to see your happy.  See you online playing Modern Warfare 2, let battle commence lol
beolion wrote:
Carl Sheerman wrote:
How do you disable the TV button on a BV 7 40 inch, and does the TV button become available when you go to select connections for your AV1 to AV 6 etc.
Carl
I am not sure about the 7-40, but on 7-55 with newest SW there is a Tunersetup menu, and here you can enable/disable the "TV-Tuner" and "DVB". If TV-TUNER is disabled, then you can assign TV to any AV connections, same goes for DVB, if this is enabled, then DTV is automatic assigned to the DVB-HD tuner, if disabled, then you can assign it to what you want.
It's the same for BV7-40 with SW7.05 😁
I use Tv butten for my Satellite reciver......
Can I disable the TV tuner on my Avant to allow the TV button to be reassigned?
Carl
Glad to hear this but now i need to get the guy in to upgrade the software then i can use the button again yipee.
