The software update - May 2014 - for the BSys4 based tv's
Indeed the new software for my V1 is arrived: Deezer, DNLA streaming, Standby function for music.... No Netradio
Nice update. I like the fact that I now can assign speaker groups to sources like spotify. And automatic picture mute on audio sources. No issues with HD.
re Joost
manitou wrote:
the new software arrived.
and my bv 11 lost contact to the ca-unit -- no hd-tv
deezer and a new picture menu are available, but what should i do without sat-tv in hd.
thank you b+o
Also applied to the new Beovision Avant V1.06. Does B&O publish a change log anywhere?
Ahh, for the BeoSystem4 stand alone as well. Really been waiting for speaker group settings :)
So what is new in the update?
and how do I know it's been done?
The dlna feature is amazing on my bv11
It works better than my Apple TV did.
Very impressed !
Update is ok, also hd channels work ok, but why there is no net radio? i do not see difference between dlna function before and after update.
@ptbb - if you use the DLNA player function (HomeMedia) as usual, you won't see any difference.
The 'tv' now acts as a 'renderer' - means rhat it plays something that you 'throw at it' from a DLNA control point (could be an iPad app or the WMP).
(At least that is how the Avant reacts. I did not have the chance to test it on my V1 yet - but it should be the same.)
Think Playmaker - the Playmaker is a renderer for audio. You pick what you want to hear and choose where to play it.
Of course the 'tv'-renderer can also play video ---- and the tv turns on from Standby (with the right settings).
Great feature - imo.
P.S. May we hope for the Netradio function in another future update? Would make these BV's perfect!
How exactly do I throw iPad content at my V1 with the new software?
thanks
I'm using this app
