The Seventh Pin ....
do anyone know, if the dealers can supply the 6th and 7th pins to the 7 pin DIN plugs?
I've bought a couple of used Beograms and both are missing those. Fortunately I have one cable with these, so I can "recycle", but not very practical.
If not dealers, any other possible source?
BR,
Pekka
Dealers can supply these, sometimes free of charge! 😕
Kind regards
Dave
You only need 1 pin for each as only one carries the datalink signal with the other being totally superfluous so you have enough to get both beograms working remotely 🙂
Chris.
