The Playmaker is now official!
Anyone allready opened the Playmaker to see which DAC IC is used?
Well I am just a user of the new technology. So a simple explanation would be helpful.
Do I understand correctly that if I add a Playmaker at A-Aux and there is a computer with MP3 files in the network that I can play and control the volume and skip MP3 songs using a Beo4 remote?
Yes and no!
You can play the files (everywhere on the ML network/in every LinkRoom) and control the volumen.
But you must chooce the content/skip tracks/create playlists via a control a DLNA compatible app on a iDevice or Smartphone/tablet (such as PlugPlayer, 8Player, Creation5).
N.B. a DLNA server (e.g. Twonky or WMP) must be running on the computer.
Or...
...you could AirPlay your content to the Playmaker - if you are a iOS user.
Greetings Millemissen
If you use Airplay, the Beo4 can change tracks and volume of the playmaker
Musicsound asked: what if  "...I ad a Playmaker at A-AUX"
In that case the PM normally is in Option 0 - and won't receive any Beo4 controls.
So, no it will not!
I have my Playmaker connected to BS9000 via aux and can change tracks with Beo4. I guess I do not have it in option 0.
What is the benefit of using option 0? Is it worth it if you lose Beo4 control?
From the installation manual:
Option: 0 - IR receiver is switched off (no reaction on IR-commands).
Option: 4 - Playmaker placed in the same room as other Bang & Olufsen products.  Remote commands must be prefixed with LINK (e.g. LINK + A.MEM).
Option: 5 - The product responds directly to its own codes (A.MEM or A.AUX).
Hence use of Option 0 will prevent both the PM and the device it is connected to responding to the same remote input.
It could be worth experimenting with Option 4 in order to have the best of both worlds.
Surely it would be worth experimenting....
Personally I would not use the Option 4 on the PM.
1: it is too complicated. The gain is to low (for me).
2: wouldn't help when listening from a LinkRoom.
3: my Playmaker is hidden away.
You all right in someway. In my opinion, if they would've have used smaller size of BeoLab 10, it would've been fantastic. And that could've even improved the sale of the Lab 10s. I think, they missed out the Art form. Most people buy their product because of the Artistic of it.
Thanks for the explanations! So it would be possible to control the songs as well if it is in option 4 or 5.
What are the disadvantages?
What about option 2,3,6,7,8... ;-)
