The new Apple TV has IR-support!
Tonight I just discovered that the apple TV remote for the ATV4 is able to control the volume on a B&O TV.
Some days ago I had benne fiddling around with the settings menu on the ATV and activated the option turn your TV on with remote. This feature doesn't work (I guess thats where HDMI CEC is needed), but the volume control works with the auto setting. It even work when I disconnect the Apple TV which suggest that the apple TV remote is able to send IR commands directly to the TV and therefore has a 455khz ir transmitter.
I have a "problem" caused by I know what not. (Update but after experimenting I do!)
But it may have been me doing some initial playing ... Or something else.
This my symptom:
- press DVD on Beo4 to activate BV and ATV
- once the main tiled screen is up I have to press the Apple Remote to get it to come alive
All that is as since day 1
However now that initial press of ATV (and this can be anything: touchpad or menu or home key) causes the BV8 to switch to TV mode !
A DVD press on the Beo4 then returns us to the ATV after which everything works until the next time we have to exit standby .....
The better news is that now with both units in standby a simple press of the Apple Remote's home key activates both the ATV and the BV (in TV mode) !
And as Madskp notes, now the Apple Remotes volume controls work on the BV ... including while it is in TV mode.
Update:
It seems the Settings option in the ATV for control of the BV was activated (I suspect while we were away for a long weekend).
Turning that off has restored the previous behaviours.
However I am sure I tested this on Day 1 and reported CEC was not working on my BV 8. Now I am wondering if the Apple implementation has changed with the update that brought folders.
Certainly Madskp 's screen shot is different from the Apple Settings screen of November last year !
Now if I move my DVD (ATV) from AV1 to AV2 I may actually get almost full integration ... power on BV and ATV with a single click of the Apple Remote's home button 🙂
elephant wrote:
This my symptom:
I can wake the apple TV from sleep with a press on the GO button the BEO4 on a BeoPlay V1
I can replicate that behavior. I found out that this only happens when "Turn on your TV with your remote" is activated. However if I disable this, the volume control from Apple Remote will still work if it is set to auto via IR.
I Guess that when the option "Turn on your TV with your remote" is activated the Apple remote will send an IR signal with a (B&O) TV command.
This doesn't make much sense for you with af Beovision 8 where the TV command is fixed to the TV source (or is it? The user manual for the MK2 states that its possible to disable both tuners to free up the TV command for other use). but on the newer Beovision/Beoplay TV's its possible to assign the TV command to the Source where the Apple TV is connected.
So here is what I Discovered you can do with the Apple remote so far in TV OS 9.2:
You can turn on a Beovision/Beoplay TV with the Apple remote's Home Button. The TV will start at the "TV" Source which should be dedicated to the Apple TV to make it work.
You can turn the Volume up and down
You can turn the TV off if you go to the menu of the Apple TV and choose sleep now. The TV doesn't turn off when the Apple TV goes to sleep after for example 15 minutes (i tried this with the Apple Remote pointing at the TV)
Only thing I can't seem to make working right now is to make the Apple TV go to sleep (and the V1 go to standby) when I press and hold the Home button on the Apple Remote which should work according to this site https://support.apple.com/en-gb/HT205225 It might be a flaw in the Current Apple TV OS.
Somehow now it also seems like my Home Button on the Apple remote won't do anything else like take me to the Homescreen, so I might have played to much around with the settings menu. Might need to reset the Apple TV and start over
After a restart of the Apple TV the Home Button now works as inteded so it is possible to put the Apple TV to sleep and turn of the V1 by holding the Home button on the Apple remote and select go to sleep now.
For some reason the volume controls suddenly didn't work, but after a source change with the BEO4 it was working again. Seems like it is not 100% stable. I will keep using it for some days and report back with my findings
I had disabled the TV button from Analogue TV some time ago and set it to Digital TV and then set DTV to be our cable box.
I might experiment on the week end at moving the ATV to the TV button port association. I think it would be neat to go from Standby directly to ATV via the Apple Remote.
having been using the Apple remote for about three weeks now it seems to be stable after the initial problems. On hiccup though is that once in a while when I press and hold the home button to make the Apple TV go to sleep the TV will turn of but then immediately turn on again. I can't tell for sure what triggers this, but I think I only experienced it in daylight. I will follow up on this behavior.
Sorry if this has been posted before in this thread, but has the Apple TV PUC been updated to reflect the new buttons on the ATV4? (ie. Home Button, for one)
This is probably because you touch some button again. Any button will turn the TV on. With B&o it works best if you turn the feature to switch on the TV off since it will not turn on the correct source. Volume up and will still work fine.
Where do I have to attach the PUC cable on the ATV4? Where is its IR eye located?
Mine is just pointed at the middle of the ATV4. Works just fine. It isn't even attached, as it doesn't stick anymore.
