Best is always difficult to answer as your own choice will always be a personal one. I prefer good vocal performance over driving bass for instance. I have either owned or used most of the above so would characterise them as follows:
S120 - a B&O insider confided in me that these were the best passive speakers made by B&O. Very well balanced though a little bass light for some tastes. accurate and relatively compact - gave these to a friend of mine along with a BC9500 which worked very well with them.
M150 - I owned MS150s which are pretty similar - big but great bass - not booming but very accurate - you can hear the bass notes rather than the boom. I find this range of tweeters tend to shriek at higher volumes and are not as relaxing to listen to as the earlier range though.
BV Penta - very pleasant sound and easy to listen to for long periods - They don't shriek but the bass is a bit one dimensional compared to the speakers with big drive units - you hear the bass but the actual notes are less distinct - there is an upper bass hump which makes them sound bassier than they actually are. I have BL Pentas, which I bought new, and these are still my main speakers.
Redline 7000 - played with the very similar RL140 - big - better than the RL60 models which I really don't like. These were made to cater for other make amplifiers and in my view don't have the traditional B&O sound, which has a very easy listening sound - sometimes described as slightly veiled.
C75/CX100 ± Cona - not really hi-fi - but I like them - I use CX100s with my 5500 as they are small and convenient. The Cona has a very high top frequency for a sub woofer and is hence directional. As I like relatively bass light sound, I have never bothered. Not a great sub woofer either!
To say what would be best also depends on budget and space. You have missed out the Beoworld favourite, the S45.2 - this can easily handle the power output of these amplifiers. Again bass light but very accurate sound and relatively compact - the later S55 is similar but much less sought after and hence cheap!
