Filled out the survey.
Basically I would want a solution that would be a cut-down beosystem forgoing loads of inputs however, combining modern toslink or HDMI-ARC & CEC.
Use case is a non-b&o tv and analogue Beolab 9. Might eventually upgrade to BL5 which has its own unique connectivity. Currently use a Beoplay s8 hub which is great, but no integrated streaming. Beosound Core now has AirPlay great, but only one input and volume control is the same flaky wheely. So basically the music system b&o doesn't want to make😭
Best would be something like Ecplise sound bar, Beoremote control, AirPlay, analogue powerlink and TV sound on/off/volume control via HDMI-CEC/ARC. So a box with an HDMI cable to tele + powerlink to BL.
If this comes to fruition, I'll buy.
