The BeoLab streaming computer
BeoMotion wrote:
I'll publish the results and some comments during or after this weekend.
20 people have voted so far.
Which price would you pay for such a device?
We can clearly see a tendency to a more costly device with more features.
Do you need a display?
Most don't need a display.
Some want to have an expensive graphic LCD.
So I think we should not include a display by default. With display it would just get too expensive.
Do you prefer the old style DIN connectors instead of the modern RJ45 ones?
Only very few like to have to old DIN connectors.
RJ45 is my favorite, too. They are much less expensive and are available as surface mount which makes manufacturing easier.
One PL connector carries left and right channel. One is enough but two are more convenient. How many?
It's 50/50. No problem here when using RJ45. So just let's include a second one.
Do you like to have a standard 38 kHz IR receiver for non-Beo remotes?
The majority don't want to have "normal" IR support. Let's leave that out. Of course it can be
 added very easily by soldering a wire to any GPIO.
Do you prefer having a 455 kHz IR receiver and a few buttons directly on the board instead of using the silver IR eye?
Again 50/50. Let's leave that out for the moment. If that device will come reality I'll order a batch of some old TSOP7000 from china. Some sellers still seem to have them in stock there. Feel free to just connect that to the IR eye screw terminal we'll add anyway. It's compatible.
Is wired ethernet important for you?
Exactly the half want to have a native ethernet port. I can understand your concerns. Although I think most people will use WiFi anyway, let's integrate it.
The device features analog and digital inputs. What would you like to connect there?
Most want to connect their BS or BV to the analog input. I didn't expect this but it's totally fine.  One more reason to have a PL input and not just a regular RCA one. Nevertheless the ADC I had in mind offers multiple inputs and we can also include a "normal" LINE-IN if there is enough space on the board in the end.
What about the case?
Hm, there is a slight tendency to just the plain PCB. Nevertheless shipping with a simple case is never a problem.
Which BL speaker you want to connect?
Just what I expected here. BL6000 and BL8000 are the clear winners! No reason for even thinking about the WISA generation.
Which streaming technologies are you using most?
Airplay and DLNA followed by Bluetooth and finally by Spotify Connect.
Are you interested in controlling old ML devices with open source hard+software?
Are you owning a BL5000 or 7000 remote?
Some people seem to be interested in this. Let's keep it for a future project.
Make a wish!
One request was IR translation support. Not sure whether this makes much sense for standard integration. Which direction do you want to translate?
Another one requested digital out support. Okay, the processor we are using offers S/PDIF out. We can bring that to a connector. Might also make some BL5 owners happy.
I'll keep the results in mind for creating a first sketch if I'll find some time over the next days.
Will keep you posted here.
Thank you for the update.
Happily waiting for your great work :-)
I guess "Ir translation" is meant like "Beo 4 in -> Sony, Panasonic etc. out" so that you can control everything with the Beo 4, 5, 6 like the PUC function from B&O or the good and flexible Lintronic TT238 Translator.
Nice idea,
Instead Ir, using Bluetooth with the Beoremote one BT ?
Cheers
Thanks BeoMotion for the summary.
I have a question regarding the ADC that you mention (had in mind), can you share which one it is?
thanks in advance
BR //Goran
I have a quesiton regarding the ADC that you mention (had in mind). can you share which one it is?
Thanks in advance
BR //Goran
Sorry, but I don't know in detail how the BR1 BT works nor do I own one. Nevertheless it might be possible to connect it to such a board...
I have good experience with TI's PCM1862. Already used in in several designs and it performs really well.
Unfortunately haven't had the time yet to start designing the board but thought about it a lot.
The survey was filled out 30 times now and most of them are also interested in ML connectivity.
That makes me think whether a fully integrated PL-only streaming solution makes that much sense at all. If there were hundreds, no question. But for maybe 50 people I think it's a little too complex.
So what about:
An USB based solution that can be easily programmed with the Arduino IDE?
With analog audio input, a nice buffer circuit and PL + ML output?
Connectors for the IR eye can also be added.
That solution would offer several benefits:
  • compatible with many streaming hosts (MAC, PC, Linux, ...)
  • easy debugging and reprogramming even for non-engineers
  • excellent for finding out how the PL and ML protocols work in detail
  • low-cost even for that small quantities
  • benefit of having a realtime MCU as we surely have to bitbang the PL protocol
What do you think?
Hey BeoMotion.
I can't understand, why tis thread disappeared, because you did bringing up, what many beoworlder are waiting for. A not so costly version of the new "core" streaming device.
Everybody wanted more and more features and when you told them, that this will be difficult (and costlier), they seemed to loose interest.
But i am very interested! If you still consider to build a non b&o "core", i will definitely buy it right now.
My only wishes are:
- i can ru it in germany (= power suply)
- i can connect it to my BL 9
- i can stream via Bluetooth and wlan eg can connect a Google chromecast audio
Can this be made?
Sorry for my bad (germanish) english and thank you for sharing your ideas with us.
Ludwig from Würzburg
Hi Ludwig,
thanks for your input!
Yes, not sure why only very few people are interested in such a solution. Manufacturing only 10 or 20 boards doesn't make that much sense to me.
This is also the reason I slowed down any progress here.
Regarding your questions: Three times YES.
So let's see where it goes.
Greetings from Berlin.
Hi
Sorry for taking this long to enter this thread. Count me in please. I like your project a lot.
MY setup is NL only. No Masterlink. I see your device connected to my BL5s digitally while sending the right data commands through powerlink to trigger them to output the digital signal.
Since upgrading from BV7 to BV12NG and putting my Overture in the attick I haven't been able to do this. I am tired of shifting between modes.
/Kim
